Dual screen en XFIRE de HD4850 - Carte graphique - Hardware
Marsh Posté le 11-07-2008 à 09:44:47
Je sais que les drivers Ati permettent de le faire, contrairement à ceux de Nvidia, mais je saurais pas t'expliquer, désolé
Marsh Posté le 15-07-2008 à 10:31:52
Mmm je me souviens avoir lu que ça marché pas très bien, mais je sais plus sur quel test (il y en a tellement en ce moment...). enfin faut que je vérifie.
Ca y est retrouvé, j'espère que ça te sert.
The Dual-screen prejudice
For the users with dual monitors. Both NVIDIA and ATI always have had the limitation that once you enable SLI or Crossfire, you pretty much loose your second screen on which you could expand your (2D) Windows desktop. For example you can not use one screen for gaming while the other shows your windows desktop.
Yesterday a forum user asked me if I wanted to check this out as apparently ATI should have fixed this with Catalyst drivers 8.1. There is a glimmer of hope, but its still buggy and unsupported...
Say you have two cards in Crossfire. Now what definitely will not work is connecting your monitors each to a separate graphics card. We tried, only one primary screen will be enabled in combo with enabling crossfire(X). Then we hooked up two monitors towards one graphics card (4850) and enabled CrossfireX again. Surprisingly, a second monitor can be enabled to expand your desktop with CF activated.
Unfortunately the minute we started playing a game, that second screen went black, and even after exiting the game, it did not come back. So support seems to be partly there yet is definitely not working properly. We see very similar behavior with NVIDIA SLI cards, and I know for a fact that they are working on solving this issue. I hope AMD will do the same.
Ca vient de Guru3D.
Marsh Posté le 15-07-2008 à 15:12:05
| MiniPierric a écrit : Mmm je me souviens avoir lu que ça marché pas très bien, mais je sais plus sur quel test (il y en a tellement en ce moment...). enfin faut que je vérifie. |
et c'est faux, j'ai un crossfireX de HD4850 et j'ai un jeu en plein écran sur mon écran de gauche pendant que mon écran de droite affiche une page web sans aucun souci.
Il gère même jusqu'à 4 écran le CCC hotfixé, donc aucun souci particulier pour le dual screen.
Marsh Posté le 16-07-2008 à 18:50:50
Houlà wobak tu es le messie
Je cherche à monter un pc permettant de jouer sur un ecran+casque pendant que ma chérie regarde un film HD. J'étais donc parti sur 2 HD4850 mais sans crossfire pour avoir le double affichage indépendant. Et là tu indiques clairement que tu arrives même à le faire en crossfire , d'autant mieux ! quoique ?
Alors, je me pose toujours la même question pour pouvoir avoir 2 applications simultanéments en plein ecran complètement indépendantes (tarckmania et videoHD) à partir du même PC :
> 1 seule CG (hd4850 ou 70) et utiliser les 2 sorties
> 2 CG (hd4850) indépendantes et utiliser une sortie sur chaque
> 2 CG (hd4580) en crossfire et utiliser une sortie sur chaque (ou 2 sur une d'ailleurs ?)
Ensuite, vaut mieux un quad 6600 ou un duo 8400, pour faire ce genre de multitâche ?
Enfin, je suis preneur de ta config précise wobak ?
d'avance merci
Marsh Posté le 25-07-2008 à 03:19:11
Wobak m'autorise à poser ses réponses si çà peut aider quelqu'un à un moment ou un autre
réponse de wobak :
Alors ma config précise est la suivante :
Intel Core 2 Duo E8400 3GHz@4GHz
4x1 Go TwinX Corsair PC6400
2x Sapphire HD4850 CrossfireX enabled
Gigabyte GA-X48-DS5
Alim Corsair 750W TX
DD Western Digital Raptor 10000RPM
et donc pour le dual screen, quand tu actives le crossfire avec le pont, dans les affichages disponibles dans le Catalyst control center, le 1 et le 3 sont les 2 sorties de la première carte, et le 2 et le 4 sont les 2 sorties de la 2e. Perso j'utilise les 2 sorties de la première carte, et une fois activé dans le CCC, dans le menu propriétés d'affichage windows, j'ai cliqué le bouton "étendre mon bureau Windows à ce moniteur".
A partir de là, j'ai du dual screen chez moi, séparé, et je joue par exemple à World of Warcraft sur mon écran de gauche, tout en surfant sur le net sur mon écran de droite, en faisant coulisser la souris tout betement...
autres questions de ma part
> Quel est ton boitier/refroidissement ?
> quel systeme xp ou vista 32 ou 64
> wow est lancé en mode fenêtré ou plein ecran ? Je demande cela car tu me parles de bureau "étendu" au lieu de dual screen. En fait je voudrais jouer plein ecran sur un moniteur lcd et lire un film hd sur la tv lcd.
> Penses tu qu'il vaille mieux désactiver le crossfire pour faire du dual ou au contraire l'activer comme tu le fait (ce que je croyais impossible en fait). Ceci en terme de performance et ou de gestion processeur
> On me conseille le quad 6600 si je veux faire du dual screen car c'est du multitâche poussé, or j'hésitais avec le duo 8400, et vu que c'est ce que tu possèdes, as tu un avis ?
réponse de wobak
>alors le refroidissement j'ai boitier antec, l'ancien modèle de ça :
http://www.antec.com/ec/fr/product [...] odID=08142
Refroidissement, j'ai un Noctua avec ventilo 12cm sur le proco, 1 ventilo 12cm à l'avant des disques et 1 extracteur 12cm à l'arrière du boitier (+ celui de l'alim)
>j'suis en xp 32b
>Wow est en fenetré maximisé (= comme en full screen, sauf que t'es pas obligé de le réduire pour passer à une autre appli). Je peux faire tourner 2 applis en plein écran genre wow et un film, si tu veux un screenshot, c'est sans souci ^^
> Perso je garde tout le temps le crossfire activé, puisque la 2e carte ne me sert que pour le calcul, mes 2 écrans étant branchés sur la première carte
> J'ai un E8400, mais overclocké à 4GHz. Si tu veux tenter le coup, il marche bien, et le dual screen tourne sans souci, maintenant si t'as les moyens, un Q6600 est toujours sympa...
Marsh Posté le 10-07-2008 à 14:40:14
Bonjour à tous
Je me posai la question si le "dualview" (possibilité d'avoir deux application en plein écran une sur chaque écran) fonctionnais sur le Crossfire de HD 4850 avec le Crossfire activé.
J'ai déja fais une recherche sur le topic adéquat mais c'est pas évident de retrouvé ses petits
Merci d'avance
