lancement open gl impossible - Carte graphique - Hardware
Marsh Posté le 16-11-2007 à 16:20:52
tu as essayer avec des drivers plus anciens
Marsh Posté le 16-11-2007 à 18:51:31
Nouvel essai avec les 7.09 meme motif meme punition
voici ce qu'indique la console de cod:CODUO 1.41 build win-x86 Aug 20 2004
----- FS_Startup -----
Current language: english
Current search path:
H:\Call of Duty\uo\pakuo06.pk3 (12 files)
H:\Call of Duty\uo\pakuo05.pk3 (3 files)
H:\Call of Duty\uo\pakuo04.pk3 (7646 files)
H:\Call of Duty\uo\pakuo03.pk3 (2275 files)
H:\Call of Duty\uo\pakuo02.pk3 (790 files)
H:\Call of Duty\uo\pakuo01.pk3 (1652 files)
H:\Call of Duty\uo\pakuo00.pk3 (6231 files)
H:\Call of Duty/uo
H:\Call of Duty\main\pak6.pk3 (3 files)
H:\Call of Duty\main\pak5.pk3 (4858 files)
H:\Call of Duty\main\pak4.pk3 (1668 files)
H:\Call of Duty\main\pak3.pk3 (1992 files)
H:\Call of Duty\main\pak2.pk3 (694 files)
H:\Call of Duty\main\pak1.pk3 (2642 files)
H:\Call of Duty\main\pak0.pk3 (12828 files)
H:\Call of Duty/main
File Handles:
49544 files in pk3 files
execing default.cfg
couldn't exec language.cfg
execing uoconfig.cfg
couldn't exec autoexec.cfg
Hunk_Clear: reset the hunk ok
...detecting CPU, found Intel Pentium III
Measured CPU speed is 2.53 GHz
System memory is 1024 MB (capped at 1 GB)
Video card memory is 1024 MB
Streaming SIMD Extensions (SSE) supported
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\system32\opengl32.dll' ): succeeded
...setting mode 8: 1280 1024 FS
...using colorbits of 32
...calling CDS: ok
...registered window class
...created window@0,0 (1280x1024)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 8 )
...35 PFDs found
...GLW_ChoosePFD failed
...GLW_ChoosePFD( 32, 24, 0 )
...35 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (8)
...shutting down QGL
...unloading OpenGL DLL
Forcing 1024x768 resolution to allow OpenGL to run in fullscreen
...initializing QGL
...setting mode 6: 1024 768 FS
...calling CDS: ok
...created window@0,0 (1024x768)
...35 PFDs found
...35 PFDs found
...WARNING: could not set the given mode (6)
Forcing 800x600 resolution to allow OpenGL to run in fullscreen
...initializing QGL
...setting mode 4: 800 600 FS
...calling CDS: ok
...created window@0,0 (800x600)
...35 PFDs found
...35 PFDs found
...WARNING: could not set the given mode (4)
Forcing 640x480 resolution to allow OpenGL to run in fullscreen
...initializing QGL
...setting mode 3: 640 480 FS
...calling CDS: ok
...created window@0,0 (640x480)
...35 PFDs found
...35 PFDs found
...WARNING: could not set the given mode (3)
----- CL_Shutdown -----
RE_Shutdown( 1 )
Chargement de OpenGL impossible. Vérifiez que vous avez correctement installé les pilotes les plus récents de carte graphique depuis le site officiel du constructeur.
Marsh Posté le 18-11-2007 à 15:41:19
truc zarbi GPUZ m'indique:
Bus interface Pcie *16 @ *1
mon bus Pcie tournerait-il à 1* au lieu de 16*
si comme je le crois oui ou puis-je bien regler cette daube???????
Marsh Posté le 18-11-2007 à 16:11:37
bah je maitrise pas trop ami bios dans advanced noth bridge conf. le parametre peg port *1 diot-il etre enable ou disabled?????
Marsh Posté le 16-11-2007 à 15:58:50
Salut a tous j' ai un probleme sur certains jeux(MOHAA,COD,COD2..)lors du lancement la console m'envoie Ch....
avec ce gentil message:
les drivers sont biens sur les derniers(cata(strpohe)lyst 7.11)
voici ma config:
asus p5b de luxe
Core 2duo 6400 @2.56Ghz
2 go de ram corsair
2 dd seagate 320Go
Sapphire 2900 pro 1Go
alim Hyper 580W
Help me if you can
