RX 480 nitro+ oc 8G , ecran bleu quand démarage programme de minage - Carte graphique - Hardware
Marsh Posté le 29-09-2016 à 13:09:03
Pour info sur ce programme nicehashminer: https://github.com/nicehash/NiceHashMiner/releases
Marsh Posté le 29-09-2016 à 13:22:26
Voici le fichier log du programme nicehashminer si ca peut aider:
12:27:59] [INFO] [NICEHASH] Starting up NiceHashMiner v1.7.1.4
[2016-09-29 12:27:59] [INFO] [NICEHASH] No config file found. Running NiceHash Miner for the first time. Choosing a default language.
[2016-09-29 12:27:59] [INFO] [NICEHASH] Found language: English
[2016-09-29 12:27:59] [INFO] [NICEHASH] Found language: Русский
[2016-09-29 12:28:04] [INFO] [NICEHASH] Selected language: English
[2016-09-29 12:28:04] [INFO] [NICEHASH] Total RAM: 8137MB
[2016-09-29 12:28:04] [INFO] [NICEHASH] Page File Size: 8136MB
[2016-09-29 12:28:04] [INFO] [ComputeDeviceQueryManager]
QueryVideoControllers:
 Win32_VideoController detected:
 	Name Radeon (TM) RX 480 Graphics
 	Description Radeon (TM) RX 480 Graphics
 	PNPDeviceID PCI\VEN_1002&DEV_67DF&SUBSYS_E347174B&REV_C7\4&176C8DF9&0&0008
 	DriverVersion 21.19.137.1
 	Status OK
[2016-09-29 12:28:04] [INFO] [MinersManager] Creating MinerPathChecker miners
[2016-09-29 12:28:04] [INFO] [AMD_OpenCL-MINER_ID(0)-DEVICE_IDs(NOT_SET)] NEW MINER CREATED
[2016-09-29 12:28:04] [INFO] [NVIDIA2.1-MINER_ID(1)-DEVICE_IDs(NOT_SET)] NEW MINER CREATED
[2016-09-29 12:28:04] [INFO] [NVIDIA3.x-MINER_ID(2)-DEVICE_IDs(NOT_SET)] NEW MINER CREATED
[2016-09-29 12:28:04] [INFO] [NVIDIA5.x-MINER_ID(3)-DEVICE_IDs(NOT_SET)] NEW MINER CREATED
[2016-09-29 12:28:04] [INFO] [NVIDIA6.x-MINER_ID(4)-DEVICE_IDs(NOT_SET)] NEW MINER CREATED
[2016-09-29 12:28:04] [INFO] [CPU0-MINER_ID(5)-DEVICE_IDs(NOT_SET)] NEW MINER CREATED
[2016-09-29 12:28:04] [INFO] [ComputeDeviceQueryManager] CudaDevicesDetection found no devices. CudaDevicesDetection returned: CUDA error in func 'CudaDetection::QueryDevices' at line 15 : CUDA driver version is insufficient for CUDA runtime version.
AMDOpenCLDeviceDetection found devices success:
 Found devices for platform: AMD Accelerated Parallel Processing
 	Device:
   Device ID 0
   Device NAME Ellesmere
   Device TYPE GPU
[2016-09-29 12:28:04] [INFO] [ComputeDeviceQueryManager] Checking AMD device (driver): Radeon (TM) RX 480 Graphics (21.19.137.1)
[2016-09-29 12:28:04] [INFO] [ComputeDeviceQueryManager] AMD platform found: Key: AMD Accelerated Parallel Processing, Num: 0
[2016-09-29 12:28:04] [INFO] [ComputeDeviceQueryManager] AMD GPUs count : 1
[2016-09-29 12:28:04] [INFO] [ComputeDeviceQueryManager] AMD Getting device name and serial from ADL
[2016-09-29 12:28:04] [INFO] [ComputeDeviceQueryManager] Number Of Adapters: 6
[2016-09-29 12:28:04] [INFO] [ComputeDeviceQueryManager] AMD OpenCL and ADL AMD query COUNTS GOOD/SAME
[2016-09-29 12:28:04] [INFO] [AmdGpuDevice] List: Ellesmere
[2016-09-29 12:28:04] [INFO] [AmdGpuDevice] GPU (Ellesmere) is optimized => NOO!
QueryAMD devices:
 ADDED device:
 	NAME: Radeon (TM) RX 480 Graphics
 	CODE_NAME: Ellesmere
 	UUID: PCI_VEN_1002&DEV_67DF_176C8DF9
 	MEMORY: 8589934592
 	ETHEREUM: YES
[2016-09-29 12:28:04] [INFO] [ComputeDeviceQueryManager] Cuda NVIDIA/CUDA device count GOOD
[2016-09-29 12:28:04] [INFO] [ComputeDeviceQueryManager] AMD GPU device count BAD!!!
[2016-09-29 12:28:04] [INFO] [ComputeDevice] The GPU detected (Ellesmere) is not Tahiti. Changing default gpu-threads to 2.
[2016-09-29 12:28:04] [INFO] [NICEHASH] Version get
[2016-09-29 12:28:05] [INFO] [NICEHASH] SMA get
[2016-09-29 12:28:05] [INFO] [COINBASE] Bitcoin rate get
[2016-09-29 12:28:05] [INFO] [COINBASE] Current Bitcoin rate: 605.00
[2016-09-29 12:28:05] [INFO] [NICEHASH] Balance get
[2016-09-29 12:28:05] [INFO] [NICEHASH] Setting environment variables
[2016-09-29 12:28:05] [INFO] [NICEHASH] Trying to enable/disable Windows error reporting
[2016-09-29 12:28:05] [INFO] [NICEHASH] Current DontShowUI value: 1
[2016-09-29 12:29:04] [INFO] [NICEHASH] SMA get
[2016-09-29 12:29:06] [INFO] [NICEHASH] Balance get
[2016-09-29 12:29:08] [INFO] [MinersDownloadManager] DownloadCompleted Success
[2016-09-29 12:29:09] [INFO] [MinersDownloadManager] bins.zip already downloaded
[2016-09-29 12:29:09] [INFO] [MinersDownloadManager] unzipping
[2016-09-29 12:29:09] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/
[2016-09-29 12:29:09] [INFO] [ZipArchiveEntry] 0
[2016-09-29 12:29:09] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/
[2016-09-29 12:29:09] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/
[2016-09-29 12:29:09] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/
[2016-09-29 12:29:09] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/
[2016-09-29 12:29:09] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/
[2016-09-29 12:29:09] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/
[2016-09-29 12:29:09] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/
[2016-09-29 12:29:09] [INFO] [ZipArchiveEntry] bin/ccminer_cryptonight.exe
[2016-09-29 12:29:09] [INFO] [ZipArchiveEntry] 7948288
[2016-09-29 12:29:09] [INFO] [ZipArchiveEntry] bin/ccminer_decred.exe
[2016-09-29 12:29:09] [INFO] [ZipArchiveEntry] 34942464
[2016-09-29 12:29:10] [INFO] [ZipArchiveEntry] bin/ccminer_nanashi.exe
[2016-09-29 12:29:10] [INFO] [ZipArchiveEntry] 46667264
[2016-09-29 12:29:11] [INFO] [ZipArchiveEntry] bin/ccminer_neoscrypt.exe
[2016-09-29 12:29:11] [INFO] [ZipArchiveEntry] 22497280
[2016-09-29 12:29:11] [INFO] [ZipArchiveEntry] bin/ccminer_sp.exe
[2016-09-29 12:29:11] [INFO] [ZipArchiveEntry] 16076288
[2016-09-29 12:29:12] [INFO] [ZipArchiveEntry] bin/ccminer_tpruvot.exe
[2016-09-29 12:29:12] [INFO] [ZipArchiveEntry] 37015040
[2016-09-29 12:29:12] [INFO] [ZipArchiveEntry] bin/cpuminer_opt_AES.exe
[2016-09-29 12:29:12] [INFO] [ZipArchiveEntry] 1545336
[2016-09-29 12:29:12] [INFO] [ZipArchiveEntry] bin/cpuminer_opt_AVX.exe
[2016-09-29 12:29:12] [INFO] [ZipArchiveEntry] 1513592
[2016-09-29 12:29:12] [INFO] [ZipArchiveEntry] bin/cpuminer_opt_AVX_AES.exe
[2016-09-29 12:29:12] [INFO] [ZipArchiveEntry] 1554552
[2016-09-29 12:29:12] [INFO] [ZipArchiveEntry] bin/cpuminer_opt_AVX2.exe
[2016-09-29 12:29:12] [INFO] [ZipArchiveEntry] 1508984
[2016-09-29 12:29:12] [INFO] [ZipArchiveEntry] bin/cpuminer_opt_AVX2_AES.exe
[2016-09-29 12:29:12] [INFO] [ZipArchiveEntry] 1550968
[2016-09-29 12:29:12] [INFO] [ZipArchiveEntry] bin/cpuminer_opt_SSE2.exe
[2016-09-29 12:29:12] [INFO] [ZipArchiveEntry] 1500280
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/cudart32_80.dll
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 296504
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/cudart64_80.dll
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 364088
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/ethminer.exe
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 1858432
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/libcrypto-1.0.0.dll
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 1518592
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/libcurl.dll
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 278016
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/libcurl-4.dll
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 361654
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/libgcc_s_seh-1.dll
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 77475
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/libgmp-10.dll
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 444399
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/libgmpxx-4.dll
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 32923
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/libjansson-4.dll
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 71103
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/libjson-c-2.dll
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 62481
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/libmicrohttpd-dll.dll
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 94208
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/libsigc-2.0-0.dll
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 26459
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/libssl-1.0.0.dll
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 358400
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/libstdc++-6.dll
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 930660
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/libwinpthread-1.dll
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 91495
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/libz-1.dll
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 108544
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/msvcr120.dll
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 970912
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/OpenCL.dll
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 21504
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/darkcoin-modHawaiigw64l4.bin
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 2015364
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/darkcoin-modPitcairngw64l4.bin
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 2176180
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/darkcoin-modPitcairngw64l4ku0.bin
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 1599452
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/darkcoin-modTahitigw64l4.bin
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 2020120
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/darkcoin-modTongagw64l4.bin
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/aes_helper.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 23816
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/alexkarnew.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 24303
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/alexkarold.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 24219
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/animecoin.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 47750
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/arebyp.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 27364
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/bitblock.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 50296
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/bitblockold.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 35049
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/blake.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 8627
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/blake256.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 3342
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/bmw.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 16317
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/bmw256.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 6712
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/bufius.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 19568
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/ckolivas.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 24223
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/credits.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 8058
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/cubehash.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 8372
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/cubehash256.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 3116
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/darkcoin.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 22808
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/darkcoin-mod.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 40309
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/diamond.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 80679
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/echo.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 5294
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/fresh.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 17447
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/fugue.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 34188
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/fuguecoin.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 6945
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/groestl.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 70723
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/groestl256.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 59894
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/groestlcoin.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 80691
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/groestlcoin-v1.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 80675
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/hamsi.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 15286
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/hamsi_helper.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 2264533
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/hamsi_helper_big.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 26366
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/inkcoin.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 7481
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/jh.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 11243
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/keccak.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 20791
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/keccak1600.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 3388
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/luffa.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 14427
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/Lyra2.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 5881
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/Lyra2RE.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 12028
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/Lyra2REv2.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 13969
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/Lyra2v2.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 5126
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/marucoin.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 26646
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/marucoin-mod.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 45259
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/marucoin-modold.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 29377
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/maxcoin.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 4660
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/myriadcoin-groestl.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 15674
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/neoscrypt.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 15811
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/panama.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 4447
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/pluck.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 17289
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/psw.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 22346
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/quarkcoin.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 50201
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/qubitcoin.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 15820
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/shabal.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 12118
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/shavite.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 21968
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/sifcoin.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 26273
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/simd.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 58075
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/skein.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 8645
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/skein256.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 3519
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/talkcoin-mod.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 11053
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/twecoin.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 12095
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/whirlcoin.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 73591
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/whirlpool.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 65196
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/x14.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 47796
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/x14old.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 33224
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/yescrypt.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 6393
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/yescrypt_essential.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 23146
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/yescrypt-multi.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 8940
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/kernel/zuikkis.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 23721
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/libcurl.dll
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 640512
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/libcurl-4.dll
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 626176
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/libeay32.dll
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 1707520
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/libgcc_s_dw2-1.dll
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 112142
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/libidn-11.dll
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 279955
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/libpdcurses.dll
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 148760
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/Lyra2REv2Hawaiigw64l4.bin
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 1066436
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/Lyra2REv2Pitcairngw64l4.bin
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 1066624
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/Lyra2REv2Tahitigw64l4.bin
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 1066608
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/Lyra2REv2Tongagw64l4.bin
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/pthreadGC2.dll
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 119704
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/quarkcoinHawaiigw256l4ku0.bin
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 1013960
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/quarkcoinHawaiigw64l4ku0.bin
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 1013944
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/quarkcoinPitcairngw256l4ku0.bin
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 1013984
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/quarkcoinPitcairngw64l4ku0.bin
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 931280
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/quarkcoinTahitigw256l4ku0.bin
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/quarkcoinTahitigw64l4ku0.bin
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 1014000
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/quarkcoinTongagw256l4ku0.bin
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/quarkcoinTongagw64l4ku0.bin
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 2324208
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/runme.bat
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 183
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/sgminer.exe
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 1539598
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/sgminer-fixed.conf
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 1912
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/ssleay32.dll
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 368640
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-0-optimized/zlib1.dll
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 113166
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/darkcoin-modHawaiigw64l4ku0.bin
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 1599428
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/darkcoin-modPitcairngw64l4ku0.bin
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/darkcoin-modTahitigw64l4ku0.bin
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/darkcoin-modTongagw64l4ku0.bin
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/aes_helper.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/alexkarnew.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/alexkarold.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/animecoin.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/arebyp.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 27386
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/bitblock.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/bitblockold.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/blake.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/blake256.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/bmw.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/bufius.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/ckolivas.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/cubehash.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/darkcoin.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/darkcoin-mod.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/diamond.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 7906
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/echo.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/fresh.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/fugue.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/fuguecoin.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/groestl.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 70714
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/groestl256.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 60640
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/groestlcoin.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/groestlcoin-v1.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/hamsi.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/hamsi_helper.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/hamsi_helper_big.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/inkcoin.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/jh.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/keccak.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/keccak1600.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/luffa.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/lyra2.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 5873
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/lyra2re.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 12068
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/marucoin.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/marucoin-mod.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/marucoin-modold.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/maxcoin.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/myriadcoin-groestl.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/neoscrypt.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/panama.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/pluck.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/psw.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/quarkcoin.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/qubitcoin.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/shabal.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/shavite.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/sifcoin.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/simd.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/skein.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/skein256.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 3521
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/talkcoin-mod.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/twecoin.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/whirlcoin.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/whirlpool.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/whirlpoolx.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 18080
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/x14.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/x14old.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/kernel/zuikkis.cl
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/libcurl.dll
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/libeay32.dll
[2016-09-29 12:29:13] [INFO] [ZipArchiveEntry] 1704448
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/libgcc_s_dw2-1.dll
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 112142
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/libidn-11.dll
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 279955
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/libpdcurses.dll
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 148760
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/pthreadGC2.dll
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 119704
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/quarkcoinHawaiigw64l4ku0.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 931264
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/quarkcoinPitcairngw64l4ku0.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 931280
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/quarkcoinTahitigw64l4ku0.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/quarkcoinTongagw64l4ku0.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/qubitcoinHawaiigw64l4ku0.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 1004216
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/qubitcoinPitcairngw64l4ku0.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 1004228
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/qubitcoinTahitigw64l4ku0.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/qubitcoinTongagw64l4ku0.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/runme.bat
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 183
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/sgminer.exe
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 1377294
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/sgminer-fixed.conf
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 1955
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/ssleay32.dll
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 364544
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-1-1-optimized/zlib1.dll
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 131598
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/darkcoin-modBonairegw64l4ku0.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 341920
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/darkcoin-modFijigw64l4ku0.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 329328
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/darkcoin-modHawaiigw64l4ku0.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 341904
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/darkcoin-modPitcairngw64l4ku0.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 389048
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/darkcoin-modTahitigw64l4ku0.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 389240
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/darkcoin-modTongagw64l4ku0.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 330680
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/aes_helper.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 23816
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/alexkarnew.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 24303
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/alexkarold.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 24219
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/animecoin.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 47750
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/arebyp.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 27386
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/bitblock.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 50296
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/bitblockold.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 35049
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/blake.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 8627
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/blake256.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 3342
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/blake256r14.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 27708
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/blake256r8.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 15725
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/bmw.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 16317
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/bmw256.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 8018
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/bufius.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 19568
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/ckolivas.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 24223
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/credits.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 8058
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/cubehash.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 8372
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/cubehash256.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 3116
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/darkcoin.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 22808
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/darkcoin-mod.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 40309
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/decred.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 28658
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/diamond.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 7906
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/echo.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 5294
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/fresh.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 17447
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/fugue.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 34188
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/fuguecoin.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 6945
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/groestl.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 70714
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/groestl256.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 60640
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/groestlcoin.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/groestlcoin-v1.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 80675
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/hamsi.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 15286
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/hamsi_helper.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 2264533
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/hamsi_helper_big.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 26366
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/inkcoin.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 7481
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/jh.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 11243
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/keccak.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 20791
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/keccak1600.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 3388
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/luffa.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 14427
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/lyra2.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 5873
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/lyra2re.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 12068
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/lyra2rev2.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 13901
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/lyra2v2.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 4980
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/marucoin.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 26646
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/marucoin-mod.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 45259
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/marucoin-modold.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 29377
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/maxcoin.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 4660
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/myriadcoin-groestl.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 15674
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/neoscrypt.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 43671
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/panama.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 4447
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/pluck.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 17289
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/psw.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 22346
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/quarkcoin.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 50201
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/qubitcoin.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 15820
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/shabal.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 12118
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/shavite.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 21968
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/sifcoin.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 26273
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/simd.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 58075
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/skein.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 8645
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/skein256.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 3521
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/talkcoin-mod.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 11053
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/twecoin.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 12095
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/vanilla.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/whirlcoin.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 73591
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/whirlpool.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 65196
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/whirlpoolx.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 18080
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/x14.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 47796
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/x14old.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 33224
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/yescrypt.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 6393
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/yescrypt_essential.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 23146
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/yescrypt-multi.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 8940
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/kernel/zuikkis.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 23721
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/lyra2rev2Bonairegw64l4.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 169696
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/lyra2rev2Fijigw64l4.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 170856
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/lyra2rev2Hawaiigw64l4.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 169688
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/lyra2rev2Pitcairngw64l4.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 205088
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/lyra2rev2Tahitigw64l4.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 205024
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/lyra2rev2Tongagw64l4.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/quarkcoinBonairegw64l4ku0.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 282176
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/quarkcoinFijigw64l4ku0.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 275536
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/quarkcoinHawaiigw64l4ku0.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 282168
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/quarkcoinPitcairngw64l4ku0.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 346808
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/quarkcoinTahitigw64l4ku0.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 346688
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/quarkcoinTongagw64l4ku0.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 279168
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/qubitcoinBonairegw64l4ku0.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 162864
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/qubitcoinFijigw64l4ku0.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 154544
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/qubitcoinHawaiigw64l4ku0.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 162856
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/qubitcoinPitcairngw64l4ku0.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 183256
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/qubitcoinTahitigw64l4ku0.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 183208
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/qubitcoinTongagw64l4ku0.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 155440
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-4-0-tweaked/sgminer.exe
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 4169728
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/bitblockFijigw64l4ku0big4.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 3505548
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/bitblockHawaiigw64l4ku0big4.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 3535836
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/bitblockTongagw64l4ku0big4.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 3505496
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/blake256r8Fijigw128l4.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 49200
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/blake256r8Hawaiigw128l4.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 49144
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/blake256r8Tongagw128l4.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/decredFijigw64l4tc24512.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 86696
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/decredHawaiigw64l4tc24512.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 86604
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/decredTongagw64l4tc24512.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 86820
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/dump.txt
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 1195321
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/aes_helper.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/alexkarnew.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/alexkarold.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/animecoin.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/arebyp.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/bitblock.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/bitblockold.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/blake.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/blake256.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/blake256r14.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/blake256r8.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/bmw.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/bmw256.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/bufius.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/ckolivas.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/credits.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/cubehash.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/cubehash256.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/darkcoin.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/darkcoin-mod.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/decred.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/diamond.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/echo.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/fresh.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/fugue.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/fuguecoin.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/groestl.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/groestl256.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/groestlcoin.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/groestlcoin-v1.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/hamsi.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/hamsi_helper.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/hamsi_helper_big.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/inkcoin.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/jh.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/keccak.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/keccak1600.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/lbry.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 5462
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/luffa.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/lyra2.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/lyra2re.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/lyra2rev2.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/lyra2v2.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/marucoin.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/marucoin-mod.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/marucoin-modold.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/maxcoin.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/myriadcoin-groestl.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/neoscrypt.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/panama.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/pluck.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/psw.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/quarkcoin.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/qubitcoin.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/ripemd160.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 17543
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/sha256.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 5636
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/shabal.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/shavite.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/sia.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 3990
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/sifcoin.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/simd.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/skein.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/skein256.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/talkcoin-mod.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/twecoin.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/vanilla.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/whirlcoin.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/whirlpool.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/whirlpoolx.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/wolf-sha512.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 4046
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/x14.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/x14old.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/yescrypt.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/yescrypt_essential.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/yescrypt-multi.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/kernel/zuikkis.cl
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/lbryTongagw128l4.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 951696
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/marucoin-modFijigw64l4ku0big4.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 3262928
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/marucoin-modHawaiigw64l4ku0big4.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 3289696
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/marucoin-modTongagw64l4ku0big4.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 3262876
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/maxcoinFijigw64l4.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 89472
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/maxcoinHawaiigw64l4.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 89372
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/maxcoinTongagw64l4.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/neoscryptFijigw64l4lgtc8192.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 260392
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/neoscryptHawaiigw64l4lgtc8192.bin
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] 269624
[2016-09-29 12:29:14] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/neoscryptTongagw64l4lgtc8192.bin
[2016-09-29 12:29:15] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/runme.bat
[2016-09-29 12:29:15] [INFO] [ZipArchiveEntry] 232
[2016-09-29 12:29:15] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/sgminer.exe
[2016-09-29 12:29:15] [INFO] [ZipArchiveEntry] 4226560
[2016-09-29 12:29:15] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/sgminer-fixed.conf
[2016-09-29 12:29:15] [INFO] [ZipArchiveEntry] 6187
[2016-09-29 12:29:15] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/talkcoin-modFijigw64l4ku0.bin
[2016-09-29 12:29:15] [INFO] [ZipArchiveEntry] 966700
[2016-09-29 12:29:15] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/talkcoin-modHawaiigw64l4ku0.bin
[2016-09-29 12:29:15] [INFO] [ZipArchiveEntry] 976860
[2016-09-29 12:29:15] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/talkcoin-modTongagw64l4ku0.bin
[2016-09-29 12:29:15] [INFO] [ZipArchiveEntry] 966768
[2016-09-29 12:29:15] [INFO] [ZipArchiveEntry] bin/sgminer-5-5-0-general/vanillaFijigw128l4.bin
[2016-09-29 12:29:15] [INFO] [ZipArchiveEntry] 49200
Marsh Posté le 29-09-2016 à 13:59:23
| Citation : [2016-09-29 12:28:04] [INFO] [ComputeDevice] The GPU detected (Ellesmere) is not Tahiti. Changing default gpu-threads to 2.   |
Ça pourrait laisser penser que les 480 soient pas encore correctement supportées …? Mais si tu dis que les 480 4Go fonctionnent…
Sinon, faudrait regarder le rapport d'erreur de Windows (avec WhoCrashed par exemple) pour voir quel type de bsod tu prends…
Marsh Posté le 29-09-2016 à 14:16:51
J'ai un problème similaire avec d'autres GUI d'ethminer avec des rx480 "8Go" ... il n'y a que goldminer qui ne me fasse pas planter ![]()
Marsh Posté le 29-09-2016 à 14:25:34
JE viens de discuter avec le creatuer de nicehash miner tu devria sessayer nicehash virrius. Le propriétaire m a filer ce lien a mettre dans le dossier de NHM : https://github.com/nicehash/NiceHas [...] d_only.zip
Et je suis entrain de faire le premier benchmark avec ma rx 480, je me demande ce que ca va donner...crash encore juste avant la fin ou bon résultat?
JE vous tiens au courant
Marsh Posté le 29-09-2016 à 14:28:34
Je veux bien parce que le minage avec Gold miner, c'est vraiment pourri, t'as aucun control ...
Tiens nous au jus ![]()
Marsh Posté le 29-09-2016 à 14:36:00
Quel système d'exploitation ?
Les écrans bleus ça ne sert pas à rien, il faut désactiver le redémarrage en cas d'erreur ou bien aller récupérer les détails du dump. Ca te dira ce qui a planté.
Mais ça a l'air d'un souci logiciel et pas hardware.
Marsh Posté le 29-09-2016 à 14:37:21
| TotalRecall a écrit :
Sauf si c'est une merde sur la mémoire de la CG, et qui du coup n'a pas d'influence en utilisation normale car les 8Go ne sont pas saturés.
Marsh Posté le 29-09-2016 à 15:22:19
Bon je reviens d un essai e nicehashminer et de la premiere étape qui est de faire un benchmark de tous les algorythme....là le conceveur de NHM m a dit de décocher tout les algorythme sauf "DaggerHashimoto" qui miner de ethereum . Il m a dit qui y avait déja eu des probleme avec cette carte + PLUS un problème de matériel reconnu par le programme£. MAis ce n est pas grave le logiciel là tourne avec cet algorythme qui génère le plus de profit par rapport aux autres. J en suis à1.38 euro de profit par jour là.
Bon n 'empêche que ça serait bien de trouver d ou vient cet écran bleu..enfin la raison , dites moi ce qu il faut que je fasse pour vous aider a trouver? CA serait quand meme sympa que quelqu un trouve sur internet enfin une solution pour ces carte RX 480 8g.
JE vous écoute.. ;-) :-)
Marsh Posté le 29-09-2016 à 15:26:44
Tes posts sont de moins en moins lisibles, ça serait possible de travailler à les décrypter eux aussi ? ![]()
Marsh Posté le 29-09-2016 à 15:26:53
Maintenant je vais rajouter ma Gtx970, pour miner a deux gpu...on va bien voir, rire, pleurer lol. Je croise les doigts. Si je répond plus c est que tout a crasher et que mon appartement brule :-p
Marsh Posté le 29-09-2016 à 15:27:39
| TotalRecall a écrit : Tes posts sont de moins en moins lisibles, ça serait possible de travailler à les décrypter eux aussi ?   |
Un café et ça ira mieux. Désolé ;-)
Marsh Posté le 29-09-2016 à 15:29:43
 Il est pas en forme aujourd'hui :\
Sinon, si tu pouvais nous poster le rapport de crash de Windows, que tu peux obtenir par exemple avec «WhoCrashed» ?
Marsh Posté le 29-09-2016 à 15:37:53
| zerist a écrit :    |
J ai installé whocrashed mais c est seulement la version pro qui fournit le detail des dumps. Y a t il un moyen sans ce programme de vous faire une copie des erreurs que j ai eu?
Marsh Posté le 29-09-2016 à 15:38:50
| laurence0006 a écrit :    |
Non non, la version standard permet de récupérer les dumps, je l'ai déjà fait des dizaines de fois, y compris récemment…
Marsh Posté le 29-09-2016 à 15:44:28
Ha autant pour moi j ai trouvé une info intéressante avec whocrashed :
Probability caused by: atikmdag.sys . Sinon je ne vois pas comment faire un copier coller des autres infos, le C/C est désactivé ainsi que la sélection.
Marsh Posté le 29-09-2016 à 15:46:47
| zerist a écrit :    |
Hé bien désolé il me dit que si je veut les détails je dois passer a la version pro.
Marsh Posté le 29-09-2016 à 15:50:57
ReplyMarsh Posté le 29-09-2016 à 15:52:27
| laurence0006 a écrit : Probability caused by: atikmdag.sys  Ca vous parle?   |
Ça veut dire que c'est la CG qui a causé le crash. Rien de bien nouveau donc…
Marsh Posté le 29-09-2016 à 15:56:29
Non rien de nouveau :-/ . J ai accès au fichier dump dans c/windows....
N y a t il pas un moyen de vous faire un copier coller de ça. Ou un lecteur de fichier dump totalement gratuit? Et windows n 'as pas prévu une commande pour avoir un rapport lisible? Windows est comme moi il est fatigué lol vivement un autre système d exploitation fonctionnel 100% ces prochaines années
Marsh Posté le 29-09-2016 à 22:48:13
| laurence0006 a écrit : Non rien de nouveau :-/ . J ai accès au fichier dump dans c/windows....   |
Plus d avis de spécialiste? Reseach captain in computer domain to save me :-)
Marsh Posté le 29-09-2016 à 22:55:35
Avant de passer d'une Nvidia GTX 970 à une AMD RX480 tu as bien sûr fait la procédure classique = désinstaller COMPLETEMENT les pilotes Nvidia? Sinon => DDU : http://www.guru3d.com/files-detail [...] nload.html
PS: si ça marche, faire cohabiter les deux cartes sera ta prochaine mission, mais j'ai des doutes.
Marsh Posté le 29-09-2016 à 23:03:41
Quel est l'intérêt de DDU au lieu de désinstaller les Driver via le panneau windows classiquement + supprimer dossier si il reste ?
Marsh Posté le 29-09-2016 à 23:45:12
Le fait qu'il reste des tonnes d'entrées de registre et de fichiers qui trainent ailleurs?
Marsh Posté le 29-09-2016 à 23:46:21
| zonka a écrit : Avant de passer d'une Nvidia GTX 970 à une AMD RX480 tu as bien sûr fait la procédure classique = désinstaller COMPLETEMENT les pilotes Nvidia? Sinon => DDU : http://www.guru3d.com/files-detail [...] nload.html   |
Merci mais je n ai pas confiance en ce logiciel, il previent bien de faire un back up au cas ou et avoir de quoi réinstaller, j ai pas la force de me retaper une instal, ca fait bien la 6eme ce mois si pour cause de test Oui, j ai désinstaller nvidia driver==>installer Rx480==> et tout a l heure j ai remis en plus ma gtx970 et donc remis nvidia driver en plus de crimson,mais la gtx970 n avais aucune puissance, en couple avec la rx480.
1:Je vais remettre une RX480 8g en plus le mois prochain , mais a votre avis je dois mettre une identique c est a dire une rx480 NITRO+ OC 8g? NITRO+ OC? la deuxieme doit être avec ce nom là aussi pour que ca fonctionne? J ai une carte mère Z97 gaming 3  de msi, je trouve peu d info a ce sujet sur les documentation et site. Excusez moi si je melange les questions.. ;-)
2: Pour savoir si ma carte graphique est de bonne facture , ne lui ferais je pas passer un benchmark puissant? Un logiciel a me conseiller? là je telecharge aida64  en trial
Marsh Posté le 30-09-2016 à 00:03:32
Tu peux aussi faire une image/clone ton système et le restaurer en cas de souci (nombre d'entre nous le font pour éviter une réinstall complète).
Bref, il faut de bons outils, de bonnes habitudes, ça évite de perdre du temps.
En ce qui concerne DDU, c'est l'option logique à tenter au vu de ton souci : BSOD causé par un pilote graphique avec changement de marque de CG et désinstallation "simple" des drivers.
Bon courage pour la suite.
Marsh Posté le 30-09-2016 à 00:14:03
| zonka a écrit : Tu peux aussi faire une image/clone ton système et le restaurer en cas de souci (nombre d'entre nous le font pour éviter une réinstall complète).   |
Bon ok je prend mon courage a deux main et je teste ça ;-) JE croise les doigts :-)
Je mets ici , un epartie de mes résultats de performande de aida64 trial. Peut être que l on y verra un peu plus clair, enfin vous:
AIDA64 Extreme
  Version   AIDA64 v5.75.3900/fr
  Module de test   4.2.685-x64
  Site web   http://www.aida64.com/
  Type de rapport   Générateur de rapports [ TRIAL VERSION ]
  Ordinateur   XXXXX-PC
  Générateur   xxxxx
  Système d'exploitation   Microsoft Windows 7 Professional 6.1.7601.17592 (Win7 RTM)
  Date   2016-09-29
  Temps   23:57
Résumé
  Ordinateur:
   Type de système   ACPI x64-based PC
   Service Pack du système   [ TRIAL VERSION ]
   Internet Explorer   8.0.7601.17514 (IE 8.0 - Windows 7 SP1)
   DirectX   DirectX 11.0
   Nom du système   XXXXX-PC
   Nom de l'utilisateur   xxxxx
   Domaine de connexion   [ TRIAL VERSION ]
   Date / Heure   2016-09-29 / 23:57
  Carte mère:
   Type de processeur   DualCore Intel Core i3-4160, 3600 MHz (36 x 100)
   Nom de la carte mère   MSI Z97 Gaming 3 (MS-7918) (3 PCI, 2 PCI-E x1, 2 PCI-E x16, 1 M.2, 4 DDR3 DIMM, Audio, Video, Gigabit LAN)
   Chipset de la carte mère   Intel Wildcat Point Z97, Intel Haswell
   Mémoire système   [ TRIAL VERSION ]
   DIMM1: Kingston 99U5584-005.A00LF   4 Go DDR3-1600 DDR3 SDRAM (11-11-11-28 @ 800 MHz) (10-10-10-27 @ 761 MHz) (9-9-9-24 @ 685 MHz) (8-8-8-22 @ 609 MHz) (7-7-7-19 @ 533 MHz) (6-6-6-16 @ 457 MHz)
   DIMM3: Kingston 99U5584-005.A00LF   [ TRIAL VERSION ]
   Type de Bios   AMI (02/16/2016)
   Port de communication   Port de communication (COM1)
   Port de communication   Port imprimante (LPT1)
  Moniteur:
   Carte vidéo   Radeon (TM) RX 480 Graphics (8 Go)
   Accélérateur 3D   AMD Polaris 10
   Accélérateur 3D   AMD Radeon RX 480 (Polaris 10)
   Moniteur   Moniteur Plug-and-Play générique [NoDB]
  Multimédia:
   Carte audio   ATI Radeon HDMI @ AMD Ellesmere - High Definition Audio Controller
   Carte audio   Realtek ALC1150 @ Intel Wildcat Point PCH - High Definition Audio Controller
  Stockage:
   Contrôleur IDE   Contrôleur Serial ATA standard AHCI 1.0
   Disque dur   Kingston DT 101 G2 USB Device (3 Go, USB)
   Disque dur   Samsung SSD 850 EVO 250GB ATA Device (250 Go, SATA-III)
   Lecteur optique   HL-DT-ST DVDRAM GH24NSD1 ATA Device (DVD+R9:8x, DVD-R9:8x, DVD+RW:24x/8x, DVD-RW:24x/6x, DVD-RAM:5x, DVD-ROM:16x, CD:48x/24x/48x DVD+RW/DVD-RW/DVD-RAM)
   État des disques durs SMART   OK
  Partitions:
   C: (NTFS)   [ TRIAL VERSION ]
   Taille totale   [ TRIAL VERSION ]
  Entrée:
   Clavier   Périphérique clavier PIH
   Souris   Souris HID
  Réseau:
   Adresse IP principale   [ TRIAL VERSION ]
   Adresse MAC principale   D8-CB-8A-C4-32-48
   Carte réseau   Killer e2200 Gigabit Ethernet Controller (192. [ TRIAL VERSION ])
  Périphériques:
   Imprimante   Fax
   Imprimante   Microsoft XPS Document Writer
   Contrôleur USB2   Intel Wildcat Point PCH - USB 2.0 EHCI Host Controller 1
   Contrôleur USB2   Intel Wildcat Point PCH - USB 2.0 EHCI Host Controller 2
   Contrôleur USB3   Intel Wildcat Point PCH - USB 3.0 xHCI Host Controller
   Périphérique USB   Generic USB Hub
   Périphérique USB   Logitech USB Headset
   Périphérique USB   Périphérique d’entrée USB
   Périphérique USB   Périphérique de stockage de masse USB
   Périphérique USB   Périphérique USB composite
  DMI:
   Distributeur du Bios   American Megatrends Inc.
   Version du Bios   V2.10
   Fabricant du système   MSI
   Nom du système   MS-7918
   Version du système   1.0
   N° de série du système   [ TRIAL VERSION ]
   UUID du système   [ TRIAL VERSION ]
   Fabricant de la carte mère   MSI
   Nom de la carte mère   Z97 GAMING 3 (MS-7918)
   Version de la carte mère   1.0
   N° de série de la carte mère   [ TRIAL VERSION ]
   Fabricant du châssis   MSI
   Version du châssis   1.0
   N° de série du châssis   [ TRIAL VERSION ]
   Identifiant du châssis   [ TRIAL VERSION ]
   Type du châssis   Desktop Case
LA suite:
Debug - PCI
  B00 D00 F00:   Intel Haswell-DT - Host Bridge/DRAM Controller
  Offset 000:   86 80 00 0C 06 00 90 20 06 00 00 06 00 00 00 00
  Offset 010:   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  Offset 020:   00 00 00 00 00 00 00 00 00 00 00 00 62 14 18 79
  Offset 030:   00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00
  Offset 040:   01 90 D1 FE 00 00 00 00 01 00 D1 FE 00 00 00 00
  Offset 050:   03 00 00 00 09 00 00 00 04 00 00 00 01 00 00 CF
  Offset 060:   03 00 00 F0 00 00 00 00 01 80 D1 FE 00 00 00 00
  Offset 070:   00 00 00 FF 01 00 00 00 00 0C 00 FF 7F 00 00 00
  Offset 080:   10 11 11 00 00 11 11 00 1A 00 00 00 00 00 00 00
  Offset 090:   01 00 00 FF 01 00 00 00 01 00 F0 2E 02 00 00 00
  Offset 0A0:   01 00 00 00 02 00 00 00 01 00 00 2F 02 00 00 00
  Offset 0B0:   01 00 00 D0 01 00 00 D0 01 00 00 CF 01 00 00 D0
  Offset 0C0:   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  Offset 0D0:   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  Offset 0E0:   09 00 0C 01 6D 83 84 62 D0 00 44 54 00 00 00 00
  Offset 0F0:   00 00 00 00 C8 0F 03 00 00 00 00 00 00 00 00 00
  B00 D01 F00:   Intel Haswell - PCI Express x16 Controller
  Offset 000:   86 80 01 0C 07 00 10 00 06 00 04 06 10 00 81 00
  Offset 010:   00 00 00 00 00 00 00 00 00 01 01 00 E0 E0 00 20
  Offset 020:   E0 EF E0 EF 01 D0 11 E0 00 00 00 00 00 00 00 00
  Offset 030:   00 00 00 00 88 00 00 00 00 00 00 00 10 01 18 00
  Offset 040:   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  Offset 050:   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  Offset 060:   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  Offset 070:   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A
  Offset 080:   01 90 03 C8 08 00 00 00 0D 80 00 00 62 14 18 79
  Offset 090:   05 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  Offset 0A0:   10 00 42 01 01 80 00 00 20 00 00 00 03 AD 61 02
  Offset 0B0:   40 00 03 D1 80 25 0C 00 00 00 40 00 00 00 00 00
  Offset 0C0:   00 00 00 00 80 0B 08 00 00 64 00 00 0E 00 00 00
  Offset 0D0:   43 00 1E 00 00 00 00 00 00 00 00 00 00 00 00 00
  Offset 0E0:   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  Offset 0F0:   00 60 01 00 4E 01 01 40 00 00 00 00 00 00 10 00
  B00 D14 F00:   Intel Wildcat Point PCH - USB 3.0 xHCI Host Controller
  Offset 000:   86 80 B1 8C 06 04 90 02 00 30 03 0C 00 00 00 00
  Offset 010:   04 00 F0 EF 00 00 00 00 00 00 00 00 00 00 00 00
  Offset 030:   00 00 00 00 70 00 00 00 00 00 00 00 00 01 00 00
  Offset 040:   FD 01 36 80 89 C6 0F 80 00 00 00 00 00 00 00 00
  Offset 050:   9F 6E 88 07 00 00 00 00 00 00 00 00 00 00 00 00
  Offset 060:   30 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  Offset 070:   01 80 C2 C1 08 00 00 00 00 00 00 00 00 00 00 00
  Offset 080:   05 00 B7 00 0C F0 E0 FE 00 00 00 00 A8 49 00 00
  Offset 090:   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  Offset 0A0:   40 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  Offset 0B0:   0F 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00
  Offset 0C0:   03 0C 30 C0 03 0C 30 00 03 0C 30 00 00 00 00 00
  Offset 0D0:   FF 3F 00 00 FF 3F 00 00 3F 00 00 00 3F 00 00 00
  Offset 0E0:   A0 00 00 00 00 00 00 00 00 00 00 00 D8 D8 D8 08
  Offset 0F0:   00 00 00 00 00 00 00 00 B1 0F 00 08 00 00 00 00
  B00 D16 F00:   Intel Wildcat Point PCH - Host Embedded Controller Interface 1 (HECI1)
  Offset 000:   86 80 BA 8C 06 04 10 00 00 00 80 07 00 00 80 00
  Offset 010:   04 90 F1 EF 00 00 00 00 00 00 00 00 00 00 00 00
  Offset 030:   00 00 00 00 50 00 00 00 00 00 00 00 00 01 00 00
  Offset 040:   55 02 00 1E 10 00 01 80 06 23 00 66 F0 1F 00 10
  Offset 050:   01 8C 03 C8 08 00 00 00 00 00 00 00 00 00 00 00
  Offset 060:   00 02 00 00 01 40 00 00 01 01 00 00 00 00 00 00
  Offset 070:   00 00 00 00 00 00 00 E0 00 00 00 00 00 00 00 00
  Offset 080:   00 00 00 00 00 00 00 00 00 00 00 00 05 00 81 00
  Offset 090:   0C F0 E0 FE 00 00 00 00 A0 49 00 00 00 00 00 00
  Offset 0A0:   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  Offset 0B0:   00 00 00 00 00 00 00 00 00 00 00 00 02 00 00 C0
  Offset 0C0:   3C 69 96 24 14 DC 20 4D 10 CE B5 14 E6 FD EB 5D
  Offset 0D0:   BB 58 D9 5B 16 EC A4 BC 6F 4D 32 86 45 76 3D AF
  Offset 0F0:   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  B00 D1A F00:   Intel Wildcat Point PCH - USB 2.0 EHCI Host Controller 2
  Offset 000:   86 80 AD 8C 06 00 90 02 00 20 03 0C 00 00 00 00
  Offset 010:   00 70 F1 EF 00 00 00 00 00 00 00 00 00 00 00 00
  Offset 030:   00 00 00 00 50 00 00 00 00 00 00 00 10 01 00 00
  Offset 040:   00 00 00 00 DB 05 00 28 00 00 00 00 00 00 00 00
  Offset 050:   01 58 C2 C9 00 00 00 00 0A 98 A0 20 00 00 00 00
  Offset 060:   20 20 FF 07 00 00 00 00 01 00 00 00 00 20 00 C0
  Offset 070:   00 00 DF 3F 03 0C 30 00 4F 01 00 00 8C 40 00 00
  Offset 080:   00 00 80 00 11 88 0C 93 70 0D 00 24 01 04 02 00
  Offset 090:   00 00 00 00 00 00 00 00 13 00 06 03 00 00 00 00
  Offset 0B0:   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  Offset 0D0:   00 00 00 00 00 AA FF 00 00 00 BD 3A 27 00 00 00
  Offset 0E0:   00 00 00 00 FF FF FF FF FF FF FF FF 34 69 EB FB
  Offset 0F0:   00 00 00 00 88 85 80 00 B1 0F 00 08 08 17 1A 20
  B00 D1B F00:   Intel Wildcat Point PCH - High Definition Audio Controller
  Offset 000:   86 80 A0 8C 06 00 10 00 00 00 03 04 10 00 00 00
  Offset 010:   04 C0 AF FE 00 00 00 00 00 00 00 00 00 00 00 00
  Offset 020:   00 00 00 00 00 00 00 00 00 00 00 00 62 14 18 D9
  Offset 030:   00 00 00 00 50 00 00 00 00 00 00 00 16 01 00 00
  Offset 040:   03 00 00 17 00 00 00 00 00 00 00 00 00 80 00 00
  Offset 050:   01 60 42 C8 00 00 00 00 00 00 00 00 00 00 00 00
  Offset 060:   05 70 80 00 00 00 00 00 00 00 00 00 00 00 00 00
  Offset 070:   10 00 91 00 00 00 00 10 00 00 10 00 00 00 00 00
  Offset 080:   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  Offset 0C0:   00 04 02 01 00 60 00 00 00 0C 85 82 10 00 33 02
  Offset 0D0:   00 0C 85 02 10 00 33 02 00 00 00 00 00 00 00 00
  B00 D1C F00:   Intel Wildcat Point PCH - PCI Express Root Port 1
  Offset 000:   86 80 90 8C 04 00 10 00 D0 00 04 06 10 00 81 00
  Offset 010:   00 00 00 00 00 00 00 00 00 02 02 00 F0 00 00 20
  Offset 020:   F0 FF 00 00 F1 FF 01 00 00 00 00 00 00 00 00 00
  Offset 030:   00 00 00 00 40 00 00 00 00 00 00 00 10 01 00 00
  Offset 040:   10 80 42 00 00 80 00 00 00 00 10 00 22 4C 31 01
  Offset 050:   00 00 01 10 60 00 04 00 00 00 40 00 00 00 00 00
  Offset 060:   00 00 00 00 17 08 08 00 00 04 00 00 00 00 00 00
  Offset 070:   02 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00
  Offset 080:   05 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  Offset 090:   0D A0 00 00 62 14 18 79 00 00 00 00 00 00 00 00
  Offset 0A0:   01 00 03 C8 00 00 00 00 00 00 00 00 00 00 00 00
  Offset 0D0:   00 00 00 01 00 08 00 00 02 00 11 09 00 00 00 00
  Offset 0F0:   50 00 00 00 80 F5 00 00 B1 0F 00 08 01 68 F5 41
  B00 D1C F02:   Intel Wildcat Point PCH - PCI Express Root Port 3
  Offset 000:   86 80 94 8C 07 00 10 00 D0 00 04 06 10 00 81 00
  Offset 010:   00 00 00 00 00 00 00 00 00 03 03 00 D0 D0 00 00
  Offset 020:   D0 EF D0 EF F1 FF 01 00 00 00 00 00 00 00 00 00
  Offset 030:   00 00 00 00 40 00 00 00 00 00 00 00 12 03 00 00
  Offset 040:   10 80 42 01 00 80 00 00 00 00 10 00 12 3C 32 03
  Offset 050:   40 00 11 70 00 B2 14 00 00 00 40 00 00 00 00 00
  Offset 060:   00 00 00 00 17 08 00 00 00 04 00 00 00 00 00 00
  Offset 0D0:   00 00 00 01 42 18 00 00 08 80 11 8B 00 00 00 00
  Offset 0E0:   02 03 00 00 00 00 00 00 03 00 00 00 00 00 00 00
  Offset 0F0:   50 00 00 00 40 00 00 0C B1 0F 00 08 00 28 00 03
  B00 D1C F03:   Intel 82801FB I/O Controller Hub 6 (ICH6) [A-0]
  Offset 000:   86 80 4E 24 07 00 10 00 D0 01 04 06 10 00 81 00
  Offset 010:   00 00 00 00 00 00 00 00 00 04 05 00 F0 00 00 20
  Offset 030:   00 00 00 00 40 00 00 00 00 00 00 00 13 04 00 00
  Offset 040:   10 80 42 01 00 80 00 00 00 00 10 00 12 4C 32 04
  Offset 050:   00 00 11 70 00 B2 1C 00 00 00 40 00 00 00 00 00
  Offset 0E0:   02 03 00 00 00 00 00 00 03 00 00 00 03 00 00 00
  Offset 0F0:   50 00 00 00 40 00 00 0C B1 0F 00 08 00 28 00 04
  B00 D1D F00:   Intel Wildcat Point PCH - USB 2.0 EHCI Host Controller 1
  Offset 000:   86 80 A6 8C 06 00 90 02 00 20 03 0C 00 00 00 00
  Offset 010:   00 60 F1 EF 00 00 00 00 00 00 00 00 00 00 00 00
  Offset 030:   00 00 00 00 50 00 00 00 00 00 00 00 17 01 00 00
  Offset 040:   00 00 00 00 DB 05 DB 13 00 00 00 00 00 00 00 00
  Offset 070:   00 00 DF 3F 03 0C 30 C0 4F 01 00 00 8C 40 00 00
  Offset 0D0:   00 00 00 00 00 AA FF 00 00 00 1C 37 27 00 00 00
  Offset 0E0:   00 00 00 00 FF FF FF FF FF FF FF FF 68 48 20 15
  B00 D1F F00:   Intel Z97 Chipset - LPC Interface Controller
  Offset 000:   86 80 C4 8C 07 00 10 02 00 00 01 06 00 00 80 00
  Offset 040:   01 18 00 00 80 00 00 00 01 1C 00 00 10 00 00 00
  Offset 050:   F8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  Offset 060:   8B 83 8B 8B 90 00 00 00 80 80 83 83 F8 F0 00 00
  Offset 070:   78 F0 78 F0 78 F0 78 F0 78 F0 78 F0 78 F0 78 F0
  Offset 080:   00 00 04 24 01 0A 7C 00 00 00 00 00 00 00 00 00
  Offset 090:   00 00 00 00 00 0F 00 00 00 00 00 00 00 00 00 00
  Offset 0A0:   18 5E A0 20 08 18 06 00 00 46 00 00 00 00 01 00
  Offset 0B0:   00 00 00 00 00 00 00 00 00 00 00 08 00 00 00 00
  Offset 0D0:   33 22 11 00 67 45 00 00 CF FF 00 00 08 00 00 00
  Offset 0E0:   09 00 0C 10 00 00 00 00 01 E8 00 90 00 00 00 00
  Offset 0F0:   01 C0 D1 FE 00 00 00 00 B1 0F 00 08 00 00 00 00
  B00 D1F F02:   Intel Wildcat Point PCH - SATA AHCI Controller 1
  Offset 000:   86 80 82 8C 07 00 B0 02 00 01 06 01 00 00 00 00
  Offset 010:   71 F0 00 00 61 F0 00 00 51 F0 00 00 41 F0 00 00
  Offset 020:   21 F0 00 00 00 50 F1 EF 00 00 00 00 62 14 18 79
  Offset 030:   00 00 00 00 80 00 00 00 00 00 00 00 13 02 00 00
  Offset 040:   00 80 00 80 00 00 00 00 00 00 00 00 00 00 00 00
  Offset 070:   01 A8 03 40 08 00 00 00 00 00 00 00 00 00 00 00
  Offset 080:   05 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  Offset 090:   60 0F 30 B0 83 01 00 0F 20 02 5C 20 20 04 00 80
  Offset 0A0:   A8 00 00 00 39 00 39 00 12 00 10 00 48 00 00 00
  B00 D1F F03:   Intel Wildcat Point PCH - SMBus Controller
  Offset 000:   86 80 A2 8C 03 00 80 02 00 00 05 0C 00 00 00 00
  Offset 010:   04 40 F1 EF 00 00 00 00 00 00 00 00 00 00 00 00
  Offset 020:   01 F0 00 00 00 00 00 00 00 00 00 00 62 14 18 79
  Offset 030:   00 00 00 00 00 00 00 00 00 00 00 00 0B 03 00 00
  Offset 040:   11 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  Offset 060:   03 04 04 00 00 00 08 08 00 00 00 00 00 00 00 00
  Offset 070:   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  Offset 080:   04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  B00 D1F F06:   Intel Wildcat Point PCH - Thermal Controller
  Offset 000:   86 80 A4 8C 00 00 10 00 00 00 80 11 00 00 00 00
  Offset 010:   04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  Offset 030:   00 00 00 00 50 00 00 00 00 00 00 00 00 03 00 00
  Offset 040:   04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  Offset 050:   01 80 23 00 08 00 00 00 00 00 00 00 00 00 00 00
  Offset 080:   05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  B01 D00 F00:   AMD Radeon RX 480 (Polaris 10) Video Adapter
  Offset 000:   02 10 DF 67 07 04 10 00 C7 00 00 03 10 00 80 00
  Offset 010:   0C 00 00 D0 00 00 00 00 0C 00 00 E0 00 00 00 00
  Offset 020:   01 E0 00 00 00 00 E0 EF 00 00 00 00 4B 17 47 E3
  Offset 030:   00 00 00 00 48 00 00 00 00 00 00 00 00 01 00 00
  Offset 040:   00 00 00 00 00 00 00 00 09 50 08 00 4B 17 47 E3
  Offset 050:   01 58 03 F6 08 00 00 00 10 A0 12 00 A1 8F 2C 01
  Offset 060:   20 29 09 00 03 09 44 00 40 01 03 11 00 00 00 00
  Offset 070:   00 00 00 00 00 00 00 00 00 00 00 00 80 09 70 00
  Offset 080:   00 04 00 00 0E 00 00 00 03 00 07 00 00 00 00 00
  Offset 0A0:   05 00 81 00 0C F0 E0 FE 00 00 00 00 B0 49 00 00
  B01 D00 F01:   AMD Ellesmere - High Definition Audio Controller
  Offset 000:   02 10 F0 AA 06 00 10 00 00 00 03 04 10 00 80 00
  Offset 010:   04 00 E6 EF 00 00 00 00 00 00 00 00 00 00 00 00
  Offset 020:   00 00 00 00 00 00 00 00 00 00 00 00 4B 17 F0 AA
  Offset 030:   00 00 00 00 48 00 00 00 00 00 00 00 11 02 00 00
  Offset 040:   00 00 00 00 00 00 00 00 09 50 08 00 4B 17 F0 AA
  Offset 050:   01 58 03 06 08 00 00 00 10 A0 12 00 A1 8F 2C 01
  Offset 080:   00 00 00 00 0E 00 00 00 00 00 01 00 00 00 00 00
  Offset 0A0:   05 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00
  B03 D00 F00:   Killer e2200 PCI-E Gigabit Ethernet Controller
  Offset 000:   69 19 91 E0 07 00 10 00 13 00 00 02 10 00 00 00
  Offset 010:   04 00 D0 EF 00 00 00 00 01 D0 00 00 00 00 00 00
  Offset 030:   00 00 00 00 40 00 00 00 00 00 00 00 12 01 00 00
  Offset 040:   01 58 C3 F9 08 00 00 00 00 00 00 00 00 00 00 00
  Offset 050:   00 00 00 00 00 00 00 00 10 C0 01 00 C5 FF 90 05
  Offset 060:   00 20 10 00 11 FC 07 00 40 00 11 10 03 00 00 00
  Offset 080:   00 00 00 00 69 19 91 E0 00 00 00 00 00 00 00 00
  Offset 0C0:   05 D8 88 01 00 00 00 00 00 00 00 00 00 00 00 00
  Offset 0D0:   00 00 00 00 00 00 00 00 11 00 0F 00 00 20 00 00
  Offset 0E0:   00 30 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  B04 D00 F00:   ASMedia ASM1083 PCI-E to PCI Bridge Controller
  Offset 000:   21 1B 80 10 04 00 10 00 03 00 04 06 10 00 01 00
  Offset 010:   00 00 00 00 00 00 00 00 04 05 05 20 F1 01 20 20
  Offset 030:   00 00 00 00 50 00 00 00 00 00 00 00 13 01 00 00
  Offset 040:   20 00 00 00 00 0F 00 00 00 00 00 00 A7 27 00 00
  Offset 050:   05 78 80 00 00 00 00 00 00 00 00 00 00 00 00 00
  Offset 060:   00 00 00 00 00 00 00 00 11 78 01 00 00 00 00 00
  Offset 070:   00 00 00 00 00 00 00 00 01 80 23 FE 08 00 00 00
  Offset 080:   10 C0 71 00 00 80 90 05 00 28 0A 00 11 DC 00 01
  Offset 090:   00 00 11 00 00 00 00 00 C0 03 00 00 00 00 00 00
  Offset 0C0:   0D 00 00 00 62 14 16 78 00 00 00 00 00 00 00 00
  PCI-8086-0C00:   Intel SNB/IVB/HSW/CRW/BDW/SKL/KBL MCHBAR @ FED10000h
  Offset 4000:   6B 71 86 15 84 41 33 88 14 11 EF B0 94 DD 5A 0B
  Offset 4010:   08 00 00 00 0B D5 00 00 00 00 00 00 00 00 00 00
  Offset 4020:   00 00 10 00 2C 00 00 00 04 00 15 00 00 00 00 00
  Offset 4280:   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  Offset 4290:   80 40 00 00 FF 98 00 00 60 18 D0 6C 58 02 00 00
  Offset 42A0:   01 00 00 00 00 82 00 41 00 00 00 00 00 00 00 00
  Offset 4400:   6B 71 86 15 84 41 33 88 14 11 EF B0 94 DD 5A 0B
  Offset 4410:   08 00 00 00 0B D5 00 00 00 00 00 00 00 00 00 00
  Offset 4420:   00 00 10 00 2C 00 00 00 04 00 15 00 00 00 00 00
  Offset 4680:   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  Offset 4690:   80 40 00 00 FF 98 00 00 60 18 D0 6C 58 02 00 00
  Offset 46A0:   01 00 00 00 00 82 00 41 00 00 00 00 00 00 00 00
  Offset 4800:   00 00 00 00 00 00 03 00 00 00 00 08 00 00 00 08
  Offset 4810:   00 00 00 08 00 00 00 08 00 00 00 08 00 00 00 08
  Offset 4A80:   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  Offset 4A90:   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  Offset 5000:   24 00 00 00 10 00 60 00 10 00 60 00 00 00 60 00
  Offset 5010:   00 00 00 00 00 00 20 10 00 00 00 00 00 00 00 00
  Offset 5880:   20 00 00 00 04 00 00 00 0D 0D 00 00 00 00 00 00
  Offset 5890:   FF FF 00 00 FF FF 00 00 FF FF 00 00 FF FF 00 00
  Offset 58A0:   00 00 00 00 00 00 00 00 94 12 00 00 00 00 00 00
  Offset 58B0:   00 00 00 00 00 00 00 00 00 00 00 00 7F 00 00 00
  Offset 58C0:   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  Offset 58D0:   FF FF 00 00 FF FF 00 00 FF FF 00 00 FF FF 00 00
  Offset 58E0:   00 00 00 00 DE 00 54 00 3D DD A6 1E 00 00 00 00
  Offset 58F0:   2E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04
  Offset 5900:   00 00 00 04 00 00 00 0C 00 00 00 00 00 00 00 00
  Offset 5910:   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  Offset 5920:   00 00 00 00 10 00 00 00 D6 06 5F 2D 00 00 00 00
  Offset 5930:   B0 01 00 00 00 00 00 00 03 0E 0A 00 F8 6E F1 DD
  Offset 5940:   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  Offset 5950:   00 00 00 00 00 00 04 00 00 24 01 F3 28 08 08 00
  Offset 5960:   00 00 00 00 53 E2 1E DD 08 7D EB 5F E6 6D 96 B8
  Offset 5970:   00 00 00 00 00 00 00 00 44 00 00 00 44 00 00 00
  Offset 5980:   34 00 00 00 3B 87 B5 07 00 00 00 00 00 00 00 00
  Offset 5990:   FF 00 00 00 FF 00 00 00 17 07 04 00 00 14 64 00
  Offset 59A0:   00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00
  Offset 59B0:   00 08 00 00 00 00 00 00 2C 00 00 2C 00 00 00 00
  Offset 59C0:   00 08 30 88 00 00 00 00 00 00 00 00 00 00 00 00
  Offset 5E00:   06 00 00 00 06 00 00 00 00 00 00 00 00 00 00 00
  Offset 5E10:   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Debug - Video BIOS
  C000:0000   U.s.....................X.....IBM.:............. 761295520......
  C000:0040   ........4.......08/02/16 04:40..5.........................!...~.
  C000:0080   ..E........<@...<.............0@.................~......P,......
  C000:00C0   .....@AC........B....}.. . .........................113-2E3470U.
  C000:0100   X51.ELLESMERE.PCI_EXPRESS.GDDR5...E347 Polaris10 XT A1 GDDR5 256
  C000:0140   Mx32 8GB 300e/300m ..... ...(C) 1988-
  C000:0180   2010, Advanced Micro Devices, Inc..ATOMBIOSBK-AMD VER015.050.000
  C000:01C0   .000.000000.347X06SU.X51.1297901 .355348 . .SAPPHIRE_ELL
  C000:0200   ESMERE_E347_NEWXTOC_A1_G5_8G_E1342M2000\config.h....$...ATOM....
  C000:0240   ..}. .......K.G.X.......PCIR...g........s.2.....AMD ATOMBIOS..x.
  C000:0280   .............S...~..]..;h....................V.....*.MP. .^..fPf
  C000:02C0   QfRfSfUfVfW...H...<.. .....u....f_f^f]f[fZfYfX...../.-2...J..H.
  C000:0300   f....<.....(.....^..U..y*.EP. u..&*..t..I...X.....X......p-..f..
  C000:0340   .....fP.....(..fXt.. f.:..r.....o/f_f^f]f[fZfYfX......<..>...u..
  C000:0380   ...........f....e.....@.....B.............|.Xa..~.....ke........
  C000:03C0   .[.............[..[..[...PMID...H...................'f....^.....
Debug - Unknown
  Monitor ID   SAM07C0: Moniteur Plug-and-Play générique [NoDB]
  Monitor Vendor   SAMSUNG
Marsh Posté le 30-09-2016 à 01:00:05
Voila c est fait , en deux temps, nettoyage des drivers nvidia, redémarage nettoyage des drivers amd.
RéInstallation de Crimson....... redémarrage..test de nicehashminer ....démarrage du programme ..et..PAF ECRAN BLEU ...
Bon j en conclue quoi? Nicehashminer ne reconnait pas encore ma carte comme il faut et j attend qu il sorte des mise a jour? Ou un test de benchmark poussé sur ma carte graphique permettrait de disculper ma carte? Un logiciel de benchmark gratuit a me conseiller? Merci a tous!
Marsh Posté le 29-09-2016 à 13:03:37
Bonjour à tous
Hier j avais une gtx970 avec driver nvidia, aujourd'hui j ai installer un RX480 8giga nitro+ oc avec crimson 16.9.2:
Pas de probleme avec un usage normale de windows 7 64 ni avec un programme de minage de coin comme ethminer a du 25Mhz là
ça se passe plutot plus rapidemant qu avec ma gtx970:
Le problème c est quand je lance mon programmme de minage favoris : nicehashminer v1.7.1.3 , quand je lance le benchmark gpu des différents algorythme , PAF écran bleu 1.5 seconde, pas le temps de lire et le pc
redémare sans broncher plus. J ai fais quelques test de benchmark sans trop pousser la chose tres loin avec des petit logiciel gratuit de benchmark et là pas de soucis.
Le problème c est avec nicehshminer, pourtant des RX 480 4 giga tourne sous hash miner mais pas ma Rx 480 nitro+ 8giga
Alors vu que je m y connai qu un petit peu en pc et que je viens juste aujourd'hui d installer cette RX 480, n aurais je pas oublier de changer un truc dans le bios, un ficher config a changer, réinstaller tout les pilotes?????
Merci pour votre aide!!
